Autoloader bundle for AutoCAD 2006
Hi Guys,
Is autoloader works for AutoCAD 2011 and lower versions?
Chandra.
Alfred.NESWADBA
afaik it was introduced with AutoCAD 2012, older versions of AutoCAD don't have that built in.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
Are you familiar with tha AcadDoc.lsp file? If you have a particular program to load every time you can edit this file to do that for you.
For instance, you open or create the AcadDoc.lsp with any text editor(i.e. Notepad), then you would enter a line that says: (load "MyProgram") and it will load everytime. The program that you are trying to load would have to
be in your support path. Otherwise you would have to hard code the path in like this: (load "C:\\My Programs\\MyProgram"). Your AcadDoc.lsp file must be in your support path.
