Autodesk support request
Hello everyone,
I write to request a direct contact with an Autodesk technician and in particular in the AutoCAD solution, please respond for internal.
Thank you!
john.vellek
Hi @Anonymous,
The forums are here for customers to obtain support from peers.  To obtain support directly from Autodesk I suggest you use the links available on your management page in your account.
If you would like to describe your issue here I am happy to work with you in the forum to see if we might be able to resolve it.
John Vellek
Good morning Mr. Vellek,
In addition to my greetings and thanking for your response, the initial request was through Autodesk Partner Center, until today, I have not received a response and I asked for help in the forum.
I would like to know if you can help me with contact, since we have a client with a problem and that I have not been able to identify.
Thank you in advance
john.vellek
Hi @Anonymous,
I don't really  have any way to check queue management but can you supply me with your case number?  I looked up the cases associated with your email and do not see any open cases.
John Vellek
Mr. Vellek,
The case number generated is 14590669 "Solicitud apoyo técnico AutoCAD".
Thank you!
john.vellek
Hi @Anonymous,
Thank you. I have moved your case to a different queue and I hope that a specialist will contact you shortly.
John Vellek
