AutoCAD Forum
Autodesk component has stopped working
5 REPLIES 5
1486 Views, 5 Replies
I am having AutoCAD 2015 for students, that worked just fine until today. I was still on the 30 days trial even though I have a serial number and product key (9 days left) - I was going to enter this info but can't open AutoCAD at all. It says
Autodesk component has stopped working. A problem caused the program to stop working correctly. Windows will close the program and notify you if a solution become available.
I uninstalled AutoCAD and installed it again, I also did restore to default settings. It didn't help. I don't think Iever  used hardware acceleration.
I am on Windows 8.1 so I assumed I should use 64 bit version.
Any ideas what else I could try?
5 REPLIES 5
pendean
in reply to: pendean
Thanks, but I don't think this is causing my problem.
My system says I am not signed in with Autodesk 360.
Also, when I get a message that component stopped working, I can't expand anything to see details. AutioCAD isn't opening at all.
Alfred.NESWADBA
Alfred.NESWADBA
Friday was Windows update-day, is it possible that you have installed the Windows updates and since then AutoCAD can't start anymore?
If so uninstall the updates and see if it's working again.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2024
(not an Autodesk consultant)
- alfred -
Alfred NESWADBA
in reply to: Alfred.NESWADBA
Thank you, it could be. Should I expect AutoCAD to stop working every time there is a Windows Update Friday? (just kidding)
Actually, its on my husband's comp so I am not sure about updates but I would expect that he is updating automatically. Right now I uninstalled AutoCAD and all components thinking to try installing again with a different user info.
I will let you know how it goes.
Thank you!
Thank you!
Finally, the brand new AutoCAD works again.
I uninstalled the old one along with all the components. Then created a different account and used IExplorer to download. I skipped Autodesk 360 as I was suggested (just in case)
Hurray!  (but for how long? )
AutoCAD Inside the Factory
