Message 1 of 17
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Every time I regen or switch tab my AutoCAD uses to much system CPU and the CAD stalls until this CPU use drops off, it doesn't appear to be using any GPU either.
I've attached a screen shot from Task manager and also the graphics tuner log, the log does say my card and driver do not meet the minimum requirement but it is on the Autodesk certified list.
I've tried all sorts of suggestions found on these boards and others and the latest driver from Nvidia is installed.
AutoCAD has become almost unusable on this PC although it has only been doing this recently so I wonder if a recent patch has messed things up.
Thanks for any help.
Chris
