Autocad zooming out issue using mouse scroll wheel
rhetths
Message 1 of 14
rhetths
I am having an issue when zooming out using my mouse scroll wheel.  Please refer video link below.
https://youtu.be/jyollPtgt9A
Replies (13)
Message 2 of 14
imadHabash
would you try to zoom out far away from your drawing then Zoom Extents . Now any changes ? also i'm interested to know if your drawing NOT far away from 0,0,0 .
if you notice that zooming stuck some where ... type REGENALL .
Imad Habash
Message 3 of 14
rhetths
The zooming out issue when using the mouse scroll wheel that i have pointed out seems independent of where the 0,0,0 is, and whilst i realise there are other zoom options, the point i am making is specifically about the zooming out issue when using the mouse scroll wheel.
The mouse scroll wheel is a quick and easy way to zoom in and out of areas of a drawing.  However, when zooming out the drawing shifts in the opposite direction to what i think it should.
Message 4 of 14
j.palmeL29YX
If you use the scrolling mouse wheel to zoom:
The point where the cursor is located always is the "fix point" and doesn't move while zooming. All other will move to this point (if zooming out) or move from this point away (if you zoom in). Knowing this, you can locate your cursor at an suitable position and then scroll the mouse whhel.
I don't yet understand your problem (?).
Jürgen Palme
Message 5 of 14
Alfred.NESWADBA
AutoCAD uses the mouse position as center for zooming, independent from zooming out or in.
And at least, this is common to all software products using a mouse-wheel. So everyone using the mouse-wheel is used to that way.
I also thought about which other mouse position (not the center of zooming) could help to give the user an orientation about how zoom will behave ... I see the center the only point that makes sense.
Here a sample using a completely different software, as you can see, the mouse position is the center for zooming ...
[video]
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
Message 6 of 14
rhetths
When i zoom in with the scroll wheel it shifts the area i have the pointer on towards the centre of the screen, which is good, whereas when i zoom out it does the opposite, the area that i have the pointer on gets further and further from the centre of the screen.
Message 7 of 14
Alfred.NESWADBA
No, not exactly, not to the "center of the screen". All geometry comes more close to the mouse position.
- alfred -
Alfred NESWADBA
Message 8 of 14
Paul_Gander
From watching your video it seems to me that you need be using PAN as well as ZOOM to navigate around your drawing.
Try holding down the scroll wheel button while you move the mouse and see if that helps you to get where you want to go.
Message 9 of 14
rhetths
I had another look and yes i can see that the point on the drawing that the pointer is on stays in the same position, however the effect of this when zooming in is that the undesired parts of the drawing shift off the screen, and you get the area of the drawing that you want.
When zooming out the opposite of what you want happens, the area of the drawing that you have the pointer on does not become the focus of the screen, instead the desired area shifts towards the edge of the screen.
In summary, the point that the pointer is pointing at stays in the same location on the screen, but the area around the pointer effectively shifts on the screen, for better when zooming in, and for worse when zooming out.
Message 10 of 14
rhetths
That is great to know and is an effective way for me to get around, thanks.
However at this point i still think the zoom out could be done a lot better.
Message 11 of 14
rhetths
Here is another video, hopefully simpler than the first one,
https://youtu.be/BzsfNgXzZS8
Message 12 of 14
rhetths
Keeping the point under the pointer in the same location at all times makes sense when you have the whole image in view, zoom in, and then zoom out, without moving the pointer at any time.
At any other time, where you say zoom in and then move the pointer, or pan, or want to refocus while zooming out, its terrible.
If my suggestion were enacted, it would mean that in the example you give, as you zoom out the point under the pointer would shift in some measure towards the middle of the screen, which would overall adjust the bearing towards the right somewhat.  Not a big problem but perhaps not what is most desired in that particular instance.
Message 13 of 14
RobDraw
Why doe it have to be about how you think it should work? This and your other noobie "questions" aren't asking for any help. If you want help, ask for help. If you have ideas about how the program should change, find an appropriate forum like AUGI's wish list.
Rob
Message 14 of 14
brandonjK8NQU
Observer
Observer
I am suffering the same issue but only when appending the drawing to a drawing navisworks, when the points that I need to use are very far away from 0,0,0. Is there a work around for this?
Brandon
