AutoCAD - Wrong vertex display when pedit polyline in block editor
3wood
Advisor Advisor
Message 1 of 8
3wood
When I edit the vertex of a pline with command PEDIT in a block editor, if the Z extrusion direction of the pline is negative, the indicative node cross is shown at wrong spots.
Is it a bug?
I attached the example dwg for testing.
[ The subject line of this post has been edited for clarity by @handjonathan Original: Wrong vertex display when pedit polyline in block editor ]
Replies (7)
Message 2 of 8
TomBeauford
Vertex in Block Editor is correct, having X scale as negative changes the display of the block but not the definition.
64bit AutoCAD Map & Civil 3D 2023
Architecture Engineering & Construction Collection
2023
Windows 10 Dell i7-12850HX 2.1 Ghz 12GB NVIDIA RTX A3000 12GB Graphics Adapter
Message 3 of 8
Kent1Cooper
For what it's worth, for me it does not do that if I edit the Block using REFEDIT rather than BEDIT.
Kent Cooper, AIA
Message 4 of 8
pendean
Community Legend
Community Legend
Run FLATTEN command in your file, that seems to fix it all:
Message 5 of 8
TomBeauford
FLATTEN does add new blocks with different names though which could cause other issues. I'd just MIRROR copy the block and BEDIT it and delete it afterwards.
2023
Message 6 of 8
3wood
Instead of pline in block, even a simple pline has the same problem. When using PEIDT the node mark runs away and appears on other side of the Y axis if the extrusion direction is (0, 0, 1).
I hope this issue can be fixed in the next version.
Message 7 of 8
3wood
I need say "Yes" when FLATTEN prompts "Remove hidden lines?", otherwise the node mark still appears at wrong location.
Message 8 of 8
3wood
You are correct. But even pline itself (not in a block) has the same issue.
