I have an issue. My ribbon and menu bar are set up like in the first picture. I want them to be like in the second picture.
Solved by cadffm. Go to Solution.
My issue is that everything is different on the top of the screen. I will mark it so that you can see the difference!
ahh,
You are talking about the ribbon-tab label position!?
I think you can't change it, it is designed this way from 2022 until now (2025)
Offtopic: But this tiny application button is unusal/not standard
Sebastian
@erayali02 schrieb:
As you can see everything is different above. I replied with examples in
the forum.
You comparing zwo different programs!
1. AutoCAD (2021)
with
2. Architecture (2022)
You can start Architecture "as AutoCAD" as well (is there no Desktop Link for?)
close your 2022 and try this:
[Win]+[R]
open:
"C:\Program Files\Autodesk\AutoCAD 2022\acad.exe" /p "AutoCAD" /product "ACA" /language "en-US"
Sebastian
