Autocad wont recognize my resolution as high enough
skelavaBXDMR
Observer Observer
skelavaBXDMR
Observer
Observer
I have my resolution on max (more than 1800) and my scale at 150%. Autocad sends a pop up message about my resolution not being high enough, and that it needs to be over 1500.. which it is! What do I do? i DONT want to lower my scale because I cant see those tiny letters.... Pls help Snimka zaslona 2025-10-20 111915.png
imadHabash
I suggest to read and follow this LINK for the latest official answer from Autodesk Support.
Imad Habash
skelavaBXDMR
Observer
Observer
But I do not want to lower my scale (as I cant see below 150%). My resolution is already on max
skelavaBXDMR
Observer
Observer
pendean
Community Legend
Community Legend
Sadly you cannot fight a program limitation (aka requirement). Sorry. It's the 150% scaling that is holding you back from keeping the 1800.
Here are the ways to open a support case with Autodesk if you are on subscription to seek out Autodesk Support's help if you want to tap them direct:
https://www.autodesk.com/support/account/manage/use/support#:~:text=com/plans.-,Contact%20support,-S...
r.capper
If just text visibility is the issue you can increase that independent of display scale.
https://support.microsoft.com/en-us/windows/change-the-size-of-text-in-windows-a19de2a4-9d5b-4d99-96...
Robin Capper
Design Systems Manager
LDE Ltd
