Hello, I recently purchased Autodesk AutoCAD but am considering changing over to AutoCAD for Architects. My application is interior design of Home Theaters. I know I can do 3D drawings using a previous version of AutoCAD, 2004, but I would like to upgrade. I see that AutoCAD Architecture allows you to utilize standard objects, such as window and doors, but my application involves building custom wall structures. Some examples of the drawings in 3-D I made can be seen in my website acousticallycorrect.net (currently under constructions). If you select "Design", it shows some of the drawings I made. My question is, does AutoCAD Architect have all the same capabilities of AutoCAD, in other words, can you use AutoCAD Architecture I in a regular AutoCAD mode if needed?.
Rick
