autocad constraints
autocad constraints
autocad constraints
Goof afternoon, I want to draw a simple echilateral triangle with geometric center (0,0).  How do i constraint it (geometrical and dimensional) so as when i do change the bottom line dimenssion into 100 (which is higher) the triangle will evolve higer simetrically and no change at geometrical point.
If there is an idee in how do i modify dimension to bottom line, i think it is good with dimension like autodesk inventor.
I will wait for an answer.
And thank you for the time.
COSMIN TESNER __>Romania.
dbroad
The easiest way would be to create a dynamic block and use a scale parameter to adjust the size, using the GCE as the insertion point.
If you must use parametric constraints, add a point on layer defpoints at 0,0, pin it, and then configure the parameters as below.
Architect, Registered NC, VA, SC, & GA.
It might be easier to use = constraints instead of angles.  After all, an equilateral triangle is defined as three equal sides, right??  🙂
beyoungjr
  1. Create 3 lines connected in an approximate triangle.
  2. Set the bottom line with a HORIZONTAL horizontal constraint.
  3. Set an ANGULAR constrain for the upper two lines.
  4. Give the upper two lines an EQUAL constraint.
  5. Give the bottom line a LINEAR constraint.
Double click the ANGULAR and Linear Constaints to set 60 degrees and any length you wish.
Here is your solution...
Blaine Young
Senior Engineering Technician, US Army
