AutoCAD Title Block Revision Sync From Vault
CAD-One
CAD-One
Hi Guys
Is it possible to for AutoCAD Title Block Revision Sync From Vault Revision?
C1
Inventor Professional 2020
Vault Professional 2020
AutoCAD 2020
CAD-One
I take it this feature is currently not available with autocad.
so I have thought of a work around. Sounds stupid, but it works.
Just before checking in and changing the state to release, i will manually place a text box with back ground masking typing in manually the next alphabet on the “Rev” corner of the title block.
The revisions table is anyways working and population revisions fine.
so after masking and releasing the Job processor will do its thing and maintain the right revision in the vault and the masked over write will show the correct rev inside the file. If I print PDF or even open file it will show the correct REV in the title block.
C1
AutoCAD 2020
CAD-One
Hi Guys,
I am still using on 2020 version.
Does any of you here use a newer version 2023 or 2024? Does the title block automatically read vault revisions?
C1
AutoCAD 2020
CAD-One
I learnt from Autodesk support. There is a better way.
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/How-to-map-an-Auto...
C1
AutoCAD 2020
