AutoCAD text input fields instantly lose focus and return to command line
austinvu
Message 1 of 23
austinvu
I am experiencing a persistent issue where any text input field in AutoCAD immediately loses focus and kicks me back to the command line. This affects all versions I’ve tested (AutoCAD 2025 and 2026).
Examples :
  • Renaming layers in the Layer Properties Manager
  • Typing dimensions at the cursor bar (Dynamic Input or Command Line)
  • Entering filenames in Save As
  • Highlighting objects (selection does not stay active)
  • Dropdown menus (they collapse after a few seconds)
Replies (22)
Message 2 of 23
paullimapa
Sounds like you may have an app running in the background that might be interrupting your mouse strokes. Have you tried replacing your mouse or keyboard?  Perhaps create a new Windows login with local admin rights then sign into using that profile to see if the problem still occurs?
Paul Li
IT Specialist
@The Office
Message 3 of 23
austinvu
I have tried both and neither work. I have also tried to reinstall windows with no success. Do you think it could be a bad keyboard driver?
Message 4 of 23
paullimapa
if you’re just using a regular keyboard and mouse then that should not be an issue
If you’re running win 11 try disabling Snap layouts to see if that makes a difference
Windows 11's Best Hidden Feature: How Snap Layouts Can Improve Your Workflow
Paul Li
IT Specialist
@The Office
Message 5 of 23
austinvu
Disabling snap layouts did not work
Message 6 of 23
paullimapa
As another test disable all startup items in windows. Also try running AutoCAD in safemode
How to start an AutoCAD Product with a minimum of plug-ins or add-ons
Paul Li
IT Specialist
@The Office
Message 7 of 23
austinvu
that did not work either. i have also reinstalled windows and autocad and checked for corrupted files
Message 8 of 23
paullimapa
See if this makes a difference
At command prompt enter:
GFXDX12
0
Thats a zero, close & restart AutoCAD
If still no good, at command prompt enter:
GRAPHICSCONFIG
Select another option under 2D Display Settings
GRAPHICSCONFIG
Disable Hardware Acceleration
Paul Li
IT Specialist
@The Office
Message 9 of 23
austinvu
im sorry but none of that worked
Message 10 of 23
paullimapa
So this problem only occurs inside AutoCAD but no other program?
If you're using a laptop, have you tried plugging the power adapter in while running the program?
Are you adventurous enough to try AutoCAD 2023 or 2024?
Paul Li
IT Specialist
@The Office
Message 11 of 23
austinvu
yes rhino, adobe, and browsers work fine. I am using a laptop and have tried it both plugged in and unplugged. I also tried autocad 2025, but the same issue was there. Autocad worked fine until sometime around april, and then this problem showed up
Message 12 of 23
paullimapa
since you're using a laptop, have you tried plugging in a separate keyboard or mouse and disabling the touchpad on the laptop?
Paul Li
IT Specialist
@The Office
Message 13 of 23
austinvu
yes i have. the problem is still there
Message 14 of 23
paullimapa
well, I've exhausted all my ideas. perhaps if you have another computer I would try installing autocad and running it on there.
Paul Li
IT Specialist
@The Office
Message 15 of 23
austinvu
ok thank you for the help! i dont have another computer, but i will keep looking for fixes
Message 16 of 23
mynamebbd
Community Visitor
Community Visitor
I have the exact same issue — whenever I try to create a new layer and name it (for example, “little layer”), I type “lit,” but the rest of the name (“tle layer”) ends up appearing in the command line instead. Please share if you find any solution.
Message 17 of 23
pendean
Community Legend
Community Legend
@austinvu @mynamebbd No one in our offices is seeing anything like that. Here are the ways to open a support case with Autodesk if you are on subscription to seek out Autodesk Support's help:
https://www.autodesk.com/support/account/manage/use/support#:~:text=com/plans.-,Contact%20support,-S...
Message 18 of 23
austinvu
I am a student, so I cannot ask for Autodesk chat support.
Message 19 of 23
justin_spruellSSX2P
Community Visitor
Community Visitor
I am having this same exact problem and have spent hours running through all of this with no luck to date and need to figure out what is really going on and how to fix - Thanks  - Justin
Message 20 of 23
catherine.watson
Hi @austinvu, I am sorry to hear this issue is persisting. Can you send me the following:
  • A screen shot of your PC's About page? You can find your PC's About page by typing "About" into Start menu search bar.
  • A screen shot of your Device Manager dialogue box with Display Adapters expanded? You can find your Device Manager by typing "Device Manager" into Start menu search bar.
Feel free to send these to me via private message if you prefer.
When you reinstalled Windows, did you do a clean reinstall or did you reinstall the OS but preserve the apps via Settings > System > Recovery > Reinstall now ?
Thanks!
Catherine Watson
Technical Support Specialist
