AutoCAD Text export to Excel
Message 1 of 11
I have to export xyz coordinates. But my z coordinates have not been input as coordinate but as a mtext.
How can I export my coordinates?
Can I convert the mtext file to text file and try exporting the text file and its corresponding x and y coordinates?
Thank you!
Replies (10)
Message 2 of 11
Alfred.NESWADBA
Command _DATAEXTRACTION (>>>details<<<).
What is a "mtext file"?
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 3 of 11
It was ,multi-line text file, which i have now exploded to make a text file.
My problem is that my z coordinates are in text form and not as points.
Any suggestions as to what can be done?
Thank you!
Message 4 of 11
Alfred.NESWADBA
The word "file" makes me unsure about what you mean, a file is stored on your harddisk or network, but it's nothing used in AutoCAD.
Do you mean MTEXT as graphic object in AutoCAD?
Why not using _DATAEXTRACTION? You can export the text-content with that command too, so you have X and Y from the insertion point (or alignment point) and the Z-value from the text-content of your TEXT or MTEXT object.
- alfred -
Alfred NESWADBA
Message 5 of 11
Yes, It works.
Does the data extracting points all be in the current layer?
Or can they be selected by swiping across them?
Because when I do that not all data are getting extracted.
Message 6 of 11
Alfred.NESWADBA
By default _DATAEXTRACTION does not look to layers, it takes all objects you select as object type independent of the layers they are sitting on.
However you can add the layer-name to the output-fields and then filter (on the wizard page where you get the preview of the data) based on specific layers.
Another option with _DATAEXTRACTION is to select the objects manually (I think it's on page 2 of the wizard), but that's unusual as you need to select objects whereas the function can select all by itself (and other reasons).
- alfred -
Alfred NESWADBA
Message 7 of 11
Thank you Alfred.
I was able to successfully extract all my points!
Message 8 of 11
Alfred.NESWADBA
Thx for feedback, good to know you got it working, - alfred -
Alfred NESWADBA
Message 9 of 11
I have problems exporting into xlz txt file ...
I tried with dataextractin but I get dxe file.
I installed lps application in AutoCAD (I saw that's the solution here: http://lee-mac.com/ptmanager.html, but I still don't know how to export.
I need it, cuz I want to import the terrain later in ArchiCad.
Thank you for help!
Message 10 of 11
Alfred.NESWADBA
Dataextraction creates 2 files:
  • DXE holds the definition for what to export, and the settings like which parameters, sorting, ... that does not hold the exported data
  • XLS or CSV or MDB which holds the exported data (as long  as you have specified to export a file and not just import the data as AutoCAD Table object) ==> that is what you are looking for
- alfred -
Alfred NESWADBA
Message 11 of 11
Thank you!
