AutoCAD Structural Detailing 2015 empty empty.iges export file
Hi, I have a problem (or maybe I am missing somehting...): I have drawn a simple beam, so I exported it to an .igs file but when I open the .igs file in inventor I get no objects...what should I do?
Thanks in advance
skintsubby
Welcome to the forums.
Can you post the original AutoCAD file?
Mark
Here are two very simple drawings, made with AutoCad Structure Dealing 2015, I've tried to converti in IGES format with an empty result when opened in inventor
skintsubby
In ASD go to ASD-Model tab. then TOOLS --> Save Model as ACIS Solids
This converts the ASD proxy objects into AutoCAD solids and saves the file as a new .dwg
Open the save AutoCAD drawing and export to IGS (or other format) from there.
Now with your suggestions something shows.
I am now trying to export to inventor the attached drawing, note that:
- in in the igs file opened in inventor there aren't the bolts
- the beams are overlapped in the same direction instead of being ortogonal like in original drawing
