I had some computer problems and IT said I would just have to create a new login. Well in this new login my preferences and settings are all lost after every time I log out.
Does anyone know if I am missing a setting or something or is this just more computer issues?
HI @Anonymous,
This sounds like a pain. Have you checked with your IT group to verify that you have adequate permissions for AutoCAD? Do you use Roaming Profiles on your network?
You might try forcing a Workspace when starting AutoCAD to see if that works.
Hi @Anonymous,
Have you checked the system variable WSAUTOSAVE? Try setting it to a value of 1 to see if that helps to retain your settings.
You can type WORKSPACE and look at the settings as well. You might try creating a unique workspace and then do a SAVEAS manually for the workspace to see if it is retained.
