AutoCAD - SELECTSIMILAR Settings
izbasar.yermekov
izbasar.yermekov
When converting a 3D model from SmartPlan3D to AutoCAD, many translucent lines are formed. It so happened that in many drawings these lines are not needed. The SELECTSIMILAR function does not have the "Transparency" criteria, and therefore, in order to remove them, you have to manually click each semi-transparent line, of which there are a lot. Is it possible to add this criterion to the settings, thereby simplifying this process?
Please find attached screenshot
[ The subject line of this post has been edited to include the product name by @handjonathan ]
cadffm
>>" The SELECTSIMILAR function does not have the "Transparency" criteria"
Right
>>"in order to remove them, you have to manually click each semi-transparent line,"
Why not using the qselect command?
>>"Is it possible to add this criterion to the settings,"
No.
The only one who can do that is AutoDESK with a new prodictversion.
Sebastian
Kent1Cooper
FILTER can find things of a specified transparency.
Kent Cooper, AIA
3wood
You can also try QSELECT.
izbasar.yermekov
Thanks my friend,
Now I now about QSELECT 😄
