AutoCAD - repeating MEASUREGEOM command
jachaczek
Observer Observer
jachaczek
Observer
Observer
I would like to ask you how improve my setup  when repeating measuregeom command (for distance), repeats as quick measurement - not the classical one for length - which is annoying and (in most cases) useless.
Thanks in advance.
J.
[ The subject line of this post has been edited to include the product name by @handjonathan ]
tramber
I didn't quite understand the point ! Because it seems to me that measuregeom is repeating with the same option unless you stop it. Then, when the command is reloaded, the distance (length) is active again....
But I suggest the use of the DIST command instead 😉
imadHabash
You may try QDIM command if it's make difference with you.
Imad Habash
jachaczek
Observer
Observer
Works! thx
