Autocad selection
H.a.r_80
Autocad selection
H.a.r_80
Hello.
I have a problem, I hope you can help me solve.
when I select a group line and polyline,
I want to cancel the selection for a specific line, but I can't, and he sends me this message:
choose the image (s) you would like to select in autocad.
Thank you...
Replies (12)
vinodkl
Hi @H.a.r_80
I am not sure if I understood your question correctly. If you want to unselect an object from selection then press the "Shift" key and then left-click on the object to remove it from the selection. Is that what you are looking for? If not then please upload a snapshot.
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
JRitner
To remove an item from a selected set, hold down the SHIFT key & pick the item to be removed. If you want to remove an item from a group, type UNGROUP at command line & select the group, then edit items as desired & GROUP to re-group selection.
Hope that helps. Good luck!
Joel Ritner
C3D Certified Professional
BIM/Systems Manager
Najarian Associates, NJ
Kent1Cooper
@vinodkl wrote:
I am not sure if I understood your question correctly. If you want to unselect an object from selection then press the "Shift" key and then left-click on the object to remove it from the selection. ....
The problem is that it's part of a GROUP.  When you Shift-select, or use the Remove option in object selection for an editing command, it un-selects the entire Group, not just the object you pick on.
Kent Cooper, AIA
vinodkl
@Kent1Cooper I assume OP missed including "of". >>When I select a group "of" polyline and line<< 😉 which makes me feel he is not talking about GROUP 🙂  only @H.a.r_80 confirm us about that.
@H.a.r_80 Are you talking about a group or individual objects? If you are talking about the group then @Kent1Cooper reply holds good,
Kent1Cooper
That part about the message is [to quote the King in The King and I] "a puzzlement!"  In addition to the question of whether or not you're talking about a GROUP [in AutoCAD's meaning of the word], what exactly are you doing to try to cancel selection of a specific line?
Kent Cooper, AIA
pendean
Community Legend
Community Legend
>>>...choose the image (s) you would like to select in autocad...<<<
@H.a.r_80 What command are you using that is only asking you to select an image?
H.a.r_80
thank you all.
Sorry for my unclear question
I draw lines over an image in AutoCAD, and when I want to delete several lines and want to return a line around the command before executing it, I do shift + wire, I can't, and it sends me the following message: choose the image you would like to select in AutoCAD.
But the Shift + Select(to deselected) feature works correctly when the image is not exist.
Thank you very mush
H.a.r_80
I use  Shift +select(to move or erase or copy …) for deselected one line out of all lines selected but when I have a image in my file enable to use Shift + select
thank you.
pendean
Community Legend
Community Legend
What is "shift + wire" exactly? Are you on a MAC or using a custom keyboard?
tboehler
Are you using Raster Design along with AutoCAD?  There is a setting for that in Raster Design "Options".
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Shift-...
H.a.r_80
I don't have Raster Design
Attached image and shift-deselect conflicting
H.a.r_80
the MAPIOPTIONS. In the Raster Extension Options dialog look under the General tab. Down near the bottom you should see "Shift+Left Click Image Selection.
This is how the problem is solved.
Thank you
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
