Command window don't showing up
cadpro78
cadpro78
My command window isn't showing up... I keep hitting CTRL-9 but this keeps appearing.  Help?
imadHabash
this message means that your command line window hiding some where.for that i suggest to change your work space and see if any changed happen.
Imad Habash
Vinayv4v
Try to autohide your taskbar and check. Your command line may be beside the taskbar.
Or right click on this portion and unlock all your taskbars from autocad.
Or as Mr Imad suggested change you workspace and check.
Cheers,
Vinay Vijayakumaran
follow the instruction to on-off autohide command line.
click <<Customize>
>>2d or 3d
>> PALETTES
>>COMMAND LINE
>> AUTO HIDE <on> or <off>
Hope it will help a lot!
