autocad selection issues when hovering solids
esacula92
Observer Observer
esacula92
Observer
Observer
I'm currently working on a house model in Autocad 2017 and I'm having issues with selecting solids. It simply doesn't highlight the right solid when hovering solids and I can't select it.
Half way the video I'm holding CTRL to select subobjects (faces) and this doesn't work well either most of the time.
I'm not sure if this is a bug or expected behavior (configuration)? Does anyone know what is causing this and how to fix? It's really frustrating.
Screen recording: https://streamable.com/ghmkz
imadHabash
please confirm that you install the latest updates? you can check from your Autodesk Desktop App .
Imad Habash
esacula92
Observer
Observer
I've just installed the updates, still the same problem unfortunately.
WarrenGeissler
Try these:
1. Turn CULLING ON - this helps to keep from selecting hidden objects.
2. Turn SELECTIONCYCLING if CULLING doesn't work. At least you are given an option.
Warren Geissler
Drafting Manager Denver Water
_____________________________________________
Please ACCEPT AS SOLUTON if this works
(...and doesn't melt your computer or cause Armageddon)
