Autocad section view question
Hello all,
I have an autocad drawing. There is a section view in paperspace. When i go into model space in that viewport and rotate the object, there seems to be a black wall thats hiding the part of object. The black wall or block is fixed in position and whatever side of the object is behind it is hidden. It is so convient to make a section view. Does anyone know how to do section this way?
jabowabo
The viewport has 3dclip clipping planes active. The clipping planes do not rotate with the model. You can turn them on/off and adjust clip depth with the 3dclip command, but you will have to redefine the section if you want the planes oriented differently.
