autocad scale
autocad scale
Message 1 of 8
autocad scale
how do i scale 0.1167 wall to 6"
Replies (7)
Message 2 of 8
pendean
Community Legend
Community Legend
Use ALIGN command's scale option.
Message 3 of 8
john.vellek
Hi @Anonymous and welcome to the Autodesk Community!
I assume that you want your entire drawing scaled properly and not just the one wall.
Turn On, Thaw, and unlock all your layers.
Type SCALE and then select ALL. A base point of 0,0 is pretty standard and then put in the scale factor of 51.41388
Please select the Accept as Solution button if my post fully solves your issue or answers your question.
John Vellek
Message 4 of 8
Patchy
and if your calculator is out of battery type in:
60000/1167    end hit enter  Smiley Very Happy
Message 5 of 8
RobDraw
What are the units of the drawing set to?
Rob
Message 6 of 8
Kent1Cooper
Welcome to these Forums!
On the assumption that the Dimension is a rounded value [likely actually 0.11666666...], you can get the result to be precisely 6" [the suggestions in Posts 3 & 4 will give you close but likewise rounded results] by using the SCALE command's Reference option.
Call up SCALE, select whatever you want to Scale along with it, and designate a base point.  Then call for the Reference option.  When it asks for a Reference length, pick on those edges with something like NEArest and PERpendicular Object Snap, so that you get precisely what the distance between them is, not rounded off.  When it asks for the New length, type in 6.
Kent Cooper, AIA
Message 7 of 8
RobDraw
I'm not convinced the drawing is in meters. There is no inch symbol on the dimension and the value is fairly close to the 6" equivalent in meters. The wall might not be a bit less than six inches, thus the difference.
Rob
Message 8 of 8
john.vellek
HI rahulsonawane2792,
I am checking back to see if my post or others helped you with your problem.
Please add a post with your results so other Forum users can benefit.
Please select the Accept as Solution button if a post or posts fully solved your issue or answered your question.
John Vellek
