AutoCAD - Saving Block so i can insert into any drawing
justin.soesbergen
justin.soesbergen
How can I save a block so it will show up in the insert block tab on any drawing?
[ The subject line of this post has been edited for clarity by @handjonathan Original:  Saving block ]
jggerth
If you insert it into your template, it will be available for any new drawing.  or are you literally asking it to show up for _any_ drawing?  including existing?
justin.soesbergen
I'm trying to get it to show up in existing ones so it can be used in PID's next time I edit them.
Is this possible or no?
RobDraw
Not without code that would insert the block upon opening. There are ways to make it readily available but it can't be inserted into drawings without opening them.
Rob
TomBeauford
No idea what version you're using but this may help: https://blogs.autodesk.com/autocad/blocks-palette-tuesday-tips-with-frank/
64bit AutoCAD Map & Civil 3D 2023
Architecture Engineering & Construction Collection
2023
Windows 10 Dell i7-12850HX 2.1 Ghz 12GB NVIDIA RTX A3000 12GB Graphics Adapter
justin.soesbergen
Thanks for the help everybody! I copied my new block to the clipboard and was able to paste it into existing drawing which I then saved as a new copy .
TomBeauford
If you only needed the ability to insert a block from another drawing you could add a macro using the
-INSERTCONTENT (Command) or use the ADCNAVIGATE (Command) in a macro to open the drawing with the block in Design Center where you could drag and drop it as easily as finding it on the insert drop-down.
Why add blocks you may not use that add to drawing size when they can be easily inserted with other means when needed? The less places they're stored the easier it will be to update them which would be easiest using Design Center with that ADCNAVIGATE macro.
2023
