AutoCAD - Profile view won't update
jenniferc2127
Observer Observer
jenniferc2127
Observer
Observer
I have now figured this out - don't know how to delete the post tho - thanks anyways
Hiya!
I've had this drawing sent to me and it's confusing me so much. When I move the alignment the profile view doesn't update with it- not even if I refresh it etc. I needed to make the alignment catchment area larger and I couldn't so I manually imported them. I just noticed that if I move the profile view the points on it don't come with unless I manually select them? And finally if I try to draw a new profile view from alignment it says select surface and there isn't one to select eventhough everything is turned on and the 'surface' layer is on.
Any ideas??
Thanks!
[ The subject line of this post has been edited to include the product name by @handjonathan ]
j.palmeL29YX
Which drawing? Here is no one attached.
And, do we talk about AutoCAD, or ...?
(If you have a Civil 3D problem, ask in the appropriate forum please. )
Jürgen Palme
jenniferc2127
Observer
Observer
I meant 'this' as in 'the drawing I am about to talk about' not that I attached one. And yes AutoCAD - I posted on the forum for it, didn't I?
handjonathan
Hi @jenniferc2127
Thanks a lot for posting your question to the forums!  
For the community to help you best, it would be great if you could attach a sample drawing to review.
Jonathan Hand
Technical Marketing Manager | Construction
