AutoCAD - Problem with 2d exercise
adamnowaczkiewicz1234
Observer Observer
Message 1 of 10
Observer
Observer
Hey, I have a problem with a certain exercise 1096 and I'm encountering it again. I don't know what to do about it. I'll try to do r33 as shown in the diagram.
First question: is it possible to connect the blocked circle to this line?
Second question: is there an easier way to do this?
I also have a problem with the previous exercise 1069. On one side of the head, I have the center point for R - 16.5, but I don't have it for R -6.5. How can I do r 6.5?
This post has been edited due to: @lauri_barnhart added the product to the title to help more community members find this topic.
Replies (9)
Message 2 of 10
vinodkl
Hello @adamnowaczkiewicz1234
Could you please share the drawing showing how much you’ve completed and where you’re facing difficulty, so I can help you out?
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
Message 3 of 10
imadHabash
Would you please show us your attempts for both exercises?
Imad Habash
Message 4 of 10
Observer
Observer
In the first diagram, I know that the circles touch each other, but I don't know how to make the circle touch the line.
In the second diagram, my idea was to lock the circle on the horizontal axis and then apply a tangent constraint. I keep finding similar problems and can't finish many exercises. adamnowaczkiewicz1234_0-1762934078783.png
Message 5 of 10
Observer
Observer
Hi i send it bellow
Message 6 of 10
j.palmeL29YX
Draw a circle with radius 16.5 - 6.5 = R10 in the center point of the R16.5 arc.
Draw a vertical line in a distance of 54/2 = 27 beside the vertical center line.
=> The intersection point between both is the center point for the R6.5 arc. (Suggestion: Draw a R6.5 circle and trim as needed)
For the other issue post your dwg please what you have untl now.
Jürgen Palme
Message 7 of 10
j.palmeL29YX
Even if you didn't yet post your attempt, here a suggestion.
(view in My Videos)
HTH
Jürgen Palme
Message 8 of 10
j.palmeL29YX
... my idea was to lock the circle on the horizontal axis and then apply a tangent constraint.
A well-meant suggestion: Before you use constraints, I would recommend training your geometric visualization skills. Otherwise, applying constraints won't really help you in the future. With the current exercises you are on a good way.
Jürgen Palme
Message 9 of 10
richard_387
If you try and use all information shown on the exercise sketch, there is a way to draw it.
With the R33 circle, you know where it hits the dia 27.8 circle. There the centre of the R33 circle is 33 from that point. Draw a circle R33 at the end of the line. You also know that the R33 circle is 33 from the R8.5 circle. So offset that circle 33. Where the two intersect is the centre of the R33 circle.
Usually the exercise diagram picture is nicely to scale, so one can insert it into the drawing to check any gross errors. Unfortunately the sketch of the exercise 1096 is not nicely drawn.
Message 10 of 10
heather_tracy
Hello @adamnowaczkiewicz1234,
Did the information provided by @j.palmeL29YX and/or @richard_387 help you and answer your question?
If yes, please click on the "Accept Solution" button. This will assist other community users in finding and benefiting from this information.
If not, please do not hesitate to give an update in this thread so all community members receive an update on the progression of your question, and can suggest next steps that may be helpful for you to achieve what you're looking for.
All the best,
Heather | Community Manager
