AutoCAD plug-in with Visual C# 2013
I am pretty new to both AutoCAD and C# programming. However, my work nature requires me to develop an AutoCAD plugin using visual C# for the purpose of AutoCAD customization.
Question 1
The customisation is as follows:
The plug-in would accept radius and a (x,y) coordinate  of the point in the circle from the user, then the output would be a circle drawn on the AutoCAD as well as the output of the coordinates of the radius.
I have found a few related codes online. However, when I typed(copied) in my visual C# window
using Autodesk.AutoCAD.Runtime;
or
using AutoCAD;
I get the error message which states 'the type or namespace name AutoCAD could not be found'.
Could anyone help me what I should do and how to overcome this?
Question 2
Though I know this question might seem pretty strange, I would like to know if the aforementioned AutoCAD customization can be done with MATLAB as I am a pretty seasoned user of MATLAB?
Could any kind soul suggest me how I should get started about doing this in the simplest way as I am overhwhlemed by the innumerbale information available online? I have also atatched a screenshot of my visual C# window.
Thanks.
Alfred.NESWADBA
to question 1:
You have to add at least two references acdbmgd.dll and acmgd.dll, on newer releases of AutoCAD also accoremgd.dll.
to question 2:
I don't know MATLAB, on their site it seems to have a development API, so it's up to you to get them together.
Just to mention: there is a specific forum for development AutoCAD based on dotNET >>>there<<<.
Good luck, - alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
