AutoCAD PDF Publish and Plot items missing
ndawsonmccann
Message 1 of 15
ndawsonmccann
My coworker has an issue when he Plots or Publishes to PDF where certain items in paper space will not appear in the PDF that is created. Another coworker has the same issue with the same file. I have tried printing the file and have not had any problems. The issue seems to be linked to a block that is inserted in to CAD. I asked my coworker to delete the block, purge the file and create a new block and the issue remains.
I have attached images of the PDF with and without errors and an error that appears in Adobe Reader when I open the PDF.
Any advice would be appreciated.
Thanks, Nick
john.vellek has embedded your image(s) for clarity
@ndawsonmccann
john.vellek has edited your subject line for clarity: PDF Publish and Plot items missing
Replies (14)
Message 2 of 15
imadHabash
can we take a look into your CAD .dwg file ? please .. if your AutoCAD is AutoCAD 2018 or later change your file format to AutoCAD 2013 from SAVE AS command then upload it here .
Imad Habash
Message 3 of 15
Alfred.NESWADBA
Is that a block or a XRef?
If it's a XRef then the other workstation can't find the file. Start command _XRef and see if there are files listed as "not found"
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
Message 4 of 15
ndawsonmccann
The block is not an XREF.
Message 5 of 15
john.vellek
Hi @ndawsonmccann,
Can you share the file(s)?  I would like to examine the contents as well as how the PDF is being produced.  Which driver is being used and with which plot style?  Are you using named Page Setups?
If your data needs to be private or confidential, please email it directly to me at john.vellek@autodesk.com and please include a link to this thread in your email.
John Vellek
Message 6 of 15
ndawsonmccann
Thanks, I have to check her eon my end if I can share the CAD files and i'll let you know.
Message 7 of 15
ndawsonmccann
I have attached the file. The sheet in question is AV-D1.04 Elevation detail 1 Man Cave. My coworker seems to think it is one of the blocks in the viewport causing the issue. He said AV-D1.03 prints just fine.
Thanks, Nick
Message 8 of 15
pendean
Community Legend
Community Legend
Not seeing anything missing here
Message 9 of 15
john.vellek
Hi @ndawsonmccann,
I, like Dean, found no problems printing the D1.04 sheet to a PDF (attached).
The only think I don't have is the CTB file that you typically use and Architxt.TTF and FangSong_GB2312.TTF.  Can you zip that up and attach it to a post so I can see if that makes any difference?
I ran my plot in AutoCAD 2019. I also ran PURGE multiple times and it was able to remove some zero-length geometry as well as some DGN linetypes.
I do see however that your file is really quite large. I wonder if you are having some memory issues when plotting this "set".  Does it behave if plotting one sheet at a time?
John Vellek
Message 10 of 15
ndawsonmccann
Hi, @john.vellek,
I do not have either of those fonts installed. The CAD user with the problem may have them installed on his computer. However, I have attached our CTB file.
Yes the file is quite large and definitely may cause an issue if my coworker was not purging the file.
It apparently works for my coworker when he prints it to one sheet.
Thanks again,
-Nick
Message 11 of 15
john.vellek
Hi @ndawsonmccann,
I don't see your CTB file attached. You might need to ZIP it before attaching to a post.
I decided that while I was waiting for it, that I would first , remove the content in the left side of the model that is unused.  I also split the Spec sheet data into its own file.
Now I have two files that are 12MB's instead of a single one at 40 MB.  In the remaining detail sheet there still appears to be a lot of content in the file that is not being used.  I suggest splitting this out too so you can get smaller file sizes.  Not only will this be faster performing but will also keep your data in smaller amounts which puts it at less risk of corruption.
If this were my project, I would put all the layouts into a Sheet set for easier maintenance, sharing of properties and perhaps easier publishing.  I attached a sample of this and it seems to work quite well. I hope this is worth some consideration.
John Vellek
Message 12 of 15
ndawsonmccann
Hey @john.vellek,
I have zipped the CTB and attached it.
I agree the file has a lot of unused content that needs deleting and purging, etc. When my coworker reached out to me at first, I deleted the tab and copied an existing tab and recreated the viewports and that seemed to do the trick. He seems to think it is due to a block. I even had him delete the block and purge and recreate the block without luck.
I am hesitant to switch over to Sheet Sets. Perhaps in the future, we still have other CAD standards to implement first and sheet sets are towards the bottom of the list.
This file is from a coworker in a different office and they are using slightly different files from me. I'm at a loss here.
Please let me know if the CTB changes anything. Thank you again for all of the help.
-Nick
Message 13 of 15
john.vellek
Hi @ndawsonmccann,
I went back to the original file you provided and used your CTB file. I used the Page setup you had provided with no changes.  I was able to plot to a multipage PDF and it appears to be intact. Adobe Reader opens it up without error.
So, to the original issue, I suspect the one computer might have  memory issue when processing the file.  You might verify that everything (OS, Drivers, Applications) are fully updated. YOu might also turn off all other apps and add-ins while working in AutoCAD to see if that helps
John Vellek
Message 14 of 15
ndawsonmccann
@john.vellek,
Thank you again for looking in to this. I will pass the info along to my coworker and check on his computer specs, etc. If i hear any further issues from him I'll report back.
Thanks, Nick
Message 15 of 15
pendean
Community Legend
Community Legend
Your posted file seems to have DGN data, they can slow down files on older AutoCAD versions
DGN ComplexData........... | Purged : 205
The file, if your colleague is interested, could also be split up into multiple DWG files all xref'ed into one top file (each dwg file is one of the many clusters of similar type of content I see in modelspace).
