01:38 PM
- Mute
- Permalink
- Report
Is there a way to throttle the frequency of these directory checks to less frequent occurrences..?
I suppose we can use Vault but I'm curious if this is configurable in AC....
thanks.
Doing a bit more research. Autocad constantly checks the source directory of files that you are using. It’s a constant back and forth from the client to the server and the shared directory. When inside the network this isn’t going to be much of a bother (except for the bandwidth that is being used up). But over a VPN connection, especially a slower one, then things are going to drag no matter what you do. So copying the files locally is probably going to be the best solution.
