Announcements
Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
AutoCAD - OSNAP Point going to XY plane and not to endpoint selected
dmillerEUQ3V
dmillerEUQ3V
I've searched the forums for this and thought I had the solution.
Dynamic UCS is off
I have all OSNAPs off
Visual Style = 2D Wireframe
Yet, no matter the point I select, the point snaps to the plane that the UCS is sitting on. I'm unable to measure anything in the Z direction it seems. Every point that is selected snaps to the XY plane.
Even ID a point that is clearly has a Z-Value tells me that point is at Z=0.
Please help, I know I have a setting somewhere that shouldn't be selected, just need help finding it.
[ The subject line of this post has been edited for clarity by @handjonathan Original:  OSNAP Point going to XY plane and not to endpoint selected ]
Replies (14)
dmillerEUQ3V
So this issue is specific to the file itself. I go into a blank file and draw a line from 0,0,0 to 0,0,25 and then do a dist from endpoint to endpoint, it comes back at 25. However, in the file I'm having issues with, I do the same thing, the distance comes back at 0.
paullimapa
post the problem file so we can take a look
Paul Li
IT Specialist
@The Office
user181
Check the OSNAPZ variable and make sure it is 0
dmillerEUQ3V
Well....there is definitely something going on with the file. I've file was over 100mb. I've deleted everything, and am left with 80 objects. All of which are lines, circles, and arcs and yet the file size is over 80mb. Something is wrong. I've purged, I've done an erase all and then removed these objects, yet the file size is grossly too much. I'm at a loss as to what else to do to make this file more manageable.
dmillerEUQ3V
I even deleted everything and purged and the file size stayed at 80mb.
pendean
Community Legend
Community Legend
Draw a line.
WBLOCK it to a new file. I suspect everything got left behind, and your new file only has that line in it.
That's how you 'delete everything' for real: repeat and select only what you wanted to keep from that 100MB file if that was your original intent.
HTH
DumR0
Hi ,
Silly question*(related to osnap on Z axes) onsap3D activated?
dmillerEUQ3V
Here is a file that I'm having the same issue with.
3DOSNAP is off.
OSNAPZ is 0.
dmillerEUQ3V
No matter the point I select for any command (line, dist, circle, etc), it jumps to the XY plane at the location of the UCS.
DumR0
your model have Z  elevation <its not flat>
 I Can measure in all direction, planes, try UCS--> W
Regarding drawing a pline, line, mline  with 3 coordonates i do not  know, try 3dpoly command.
in AutoCAD 3D if you need to draw auxiliary lines , shapes etc you need to change the UCS to view you need
3Dosnap must be activated to osnap to 3D nodes.
your DWG have modifyd BASE. i do not know if it matters,
pendean
Community Legend
Community Legend
That's how your BASE and PLAN commands are set: what other behavior are you trying to achieve exactly if I may ask?
Also, see attached: "new block" is a WBLOCK of your posted file, about as small as it will ever get with that content intact in it that is that busy (you have some good detailed blocks in there). "new empty" is me erasing everything in that 'wblock' file and saving it. Way smaller.
dmillerEUQ3V
This is what is happening. I issue the dist command, select an endpoint in the red circle, and instead of selecting that point, it snaps to where the point lies (green circle) on the XY plane where the UCS is. I do not want that. I want the point I selected to be the point, not the equivalent in the XY plane.
BASE Command just says 0,0,0. Not sure how that stops AutoCAD from going to the XY plane.
I just want the point I select to stay selected.
dmillerEUQ3V
Ok, so when I open the file in AutoCAD 2021, the issue does not present itself. It seems to be something with AutoCAD 2023 Mechanical.
Why on earth would that make a difference? It's a setting in Mechanical that is doing this. What is the setting?
dmillerEUQ3V
AutoCAD Mechanical 2021, it works as expected.
