AutoCAD on Windows 10
john.vellek
Alumni Alumni
Message 1 of 11
john.vellek
Do you have a new computer with Windows 10? Which versions of AutoCAD will work on it?
John Vellek
Replies (10)
Message 2 of 11
john.vellek
While Microsoft Windows 10 is not yet an officially supported operating system across the entire Autodesk product line, it does run AutoCAD 2015 and newer products.
Older versions (2013-2014), if installed prior to an operating system upgrade to Windows 10 should continue to function but are not supported configurations.
AutoCAD 2015 will install if Windows 10 update KB3081448 or later has been applied to the operating system.
For a list of supported AutoCAD versions and the required Windows updates or AutoCAD Service Packs, refer to this AKN Article.
Service Packs and Hotfixes can be found here.
Here are the system requirements for:
AutoCAD 2017
AutoCAD 2016
AutoCAD 2015
AutoCAD 2014
AutoCAD 2013
John Vellek
Message 3 of 11
Windows 10 Home ... not way to install AUTOCAD ? ...please helpto find a solution
only with Windows 10 (Desktop OS) is it possible?
Thanks 🙂
Message 4 of 11
watkins.erik
Are there issues with loading AutoCAD 2017 on a Windows 7 machine?  My computer meets all the requirements from AutoDesk but I'm getting this error (see pic).  Thx.
Message 5 of 11
ennujozlagam
@watkins.erik hello , try to download the autocad software from virtual agent. clear all your temp folder in c: drive those cannot delete just skip. switch off all your anti virus program and firewall before downloading and installations. thanks
click HERE
Message 6 of 11
ennujozlagam
@Anonymous hello , try to download the autocad software from virtual agent. clear all your temp folder in c: drive those cannot delete just skip. switch off all your anti virus program and firewall before downloading and installations. thanks
click HERE
Message 7 of 11
watkins.erik
Thanks.  I did clear my temp files and I didn't have an issue with my virus program or fire wall.  It actually installs on my computer but when I go to open it, it gives me that error.  I've tried to uninstall, and re-install - to no avail.
Message 8 of 11
ennujozlagam
@watkins.erik hello, before you open your autocad try to install latest updates and service packs from autodesk and see if can solve your issue. thanks
Message 9 of 11
watkins.erik
I have a totally updated computer I'm working on.  I am loading 2016, it actually prompted me for my serial # before installing it.  I think 2017 just isn't ready yet, not sure why they even give you an option to download it.  Oh well.  Thanks for your time!
Message 10 of 11
john.vellek
Hi @watkins.erik,
I am sorry to see that you are having issues installing AutoCAD 2017 on your computer. The error you are seeing is indicating that a C++ component is not installed. This is an element that is from Microsoft and is typically installed via Windows Updates.
Here is an AKN Article that describes two different processes to get this rectified so that you can get your AutoCAD installed and running. If you continue to have difficulties I suggest you post in the Installation and Licensing forum here.
John Vellek
Message 11 of 11
john.vellek
Hi @Anonymous,
There should be no issues in installing and running AutoCAD 2017 on the Windows 10 Home version as opposed to Windows 10. I suggest downloading a trial using the Virtual Agent and install it on your system. If you run into any installation problems then I suggest that you post in the Installation and Licensing forum for additional support from the Community.
John Vellek
