AutoCAD Forum
Autocad Not Working
3 REPLIES 3
423 Views, 3 Replies
Autocad Not Working
I had this problem before and uninstalled the application manager. Then it worked but sometimes when I open the program it takes too long to load it and then when it opens it doesnt respond to any command. It doesnt even close. I have to close it through the task manager.
I tried to find if the application manager is there now and it is not, so I dont know what else can I do. Restated many times. I the past it sometimes worked if I restarted the compure...
Any suggestions?
Thank you!
Cecilia
3 REPLIES 3
pendean
Windows version?
AutoCAD version?
in reply to: pendean
Can you help me?
I created a block in another dwg, imported it into a new one and re-scaled it. After a while the hach of the blocks imported showed with a pattern instead of solid.
I tried to do the hatch again in the new drawing and the solid hatch shows with a pattern still...the drawing became too sloww too...
Thank you!
Cecilia
pendean
It was probably not a SOLID hatch to start with, but a very small scale pattern that you see now.
You can use BEDIT or REFEDIT commands to edit the block then replace the hatch.
AutoCAD Inside the Factory
