AutoCAD - Not able to explode object
emma.odering
emma.odering
Hi.
Could anybody please tell me why I am unable to explode the exterior walls? I need to change the measurements but I can't explode it to do so. Thanks.
[ The subject line of this post has been edited to include the product name by @handjonathan ]
imadHabash
If the blocks are not minserted blocks, check if you have unchecked the “Allow exploding” option when defining your block .It's good idea to have a CAD dwg sample for testing?
Imad Habash
emma.odering
I've attached the drawing. Thanks.
emma.odering
Kent1Cooper
[For me, that required recovery, there were errors, and it ended up with only title-blocks -- no walls, etc.]
Kent Cooper, AIA
imadHabash
Thanks for your CAD file ..
You're working with group .. for that you may need to start UNGROUP command . >> Click <<
Imad Habash
