AutoCAD Network Resource Utilization
Has anyone used the AutoCAD Network ?
I wonder how is the installation and access .
How do I calculate the use of network resources for this type of use ?
I would like to install on a server and users would connect this to use the tool . In this case access is done via RDP ?
dgorsman
If you mean, multiple users remoting in there are specific technical and licensing requirements.  This is best done in a sit-down meeting with your reseller to ensure you understand everything that is required.
DarrenP
Autodesks stance: http://knowledge.autodesk.com/search-result/caas/sfdcarticles/sfdcarticles/Autodesk-Virtualization-F...
DarrenP
About licensing requirements I understand.  But I wan't to know about the resource utilization for this kind of use. (over network)
