AutoCAD Forum
Autocad Mpa 3d missing annotative status bar buttons
6 REPLIES 6
529 Views, 6 Replies
We have some guys running autocad map 3d.  I am running civil 3d.  I can right click on the status bar and add/remove annotative scale/ visibility etc with ease.
They do not have these buttons and we can't find where to add them on the Map 3d.
They are running a template from head office..could they have removed those buttons through system variables or something like that?
Any ideas?
Basically we would like to start using annotative text but its a super pain without the buttons in the status bar.   We can use the text commands so it obviously functions in map 3d but for some reason I can't get the buttons to show.
6 REPLIES 6
braudpat
Hello from France
Welcome to the Autodesk/AutoCAD Forums !
You have to play with REGEDIT ...
HKEY_CURRENT_USER
-- Software
---- Autodesk
------ AutoCAD
-------- R17.0
---------- ACAD-500x:40C
------------ Applications
-------------- AcMap
Create (if necessary) the Key (DWORD) "Statusbar"
If Value = 0  -  Status Bar = "Classic AutoCAD"
If Value = 1  -  Status Bar = "MAP 3D 201x"
HKEY_CURRENT_USER / Software / Autodesk / AutoCAD / R1x.x
Key: R17.0 pour MAP/CIVIL 2007
Key: R17.1 pour MAP/CIVIL 2008
Key: R17.2 pour MAP/CIVIL 2009
Key: R18.0 pour MAP/CIVIL 2010
Key: R18.1 pour MAP/CIVIL 2011
Key: R18.2 pour MAP/CIVIL 2012
Key: R19.0 pour MAP/CIVIL 2013
Key: R19.1 pour MAP/CIVIL 2014
Key: R20.0 pour MAP/CIVIL 2015
*** ACAD CIVIL 2015 *** To get the MAP Look (on the status bar) ***
HKEY_CURRENT_USER / Software / Autodesk / AutoCAD / R20.0 / ACAD-E000:40C / Applications / AcMap
Statusbar :  0  -->  1
Happy New Year and THE HEALTH !
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
Alfred.NESWADBA
not sure to understand you correctly, but try (for newer Civil 3D releases) to type in command _MAPSTATUSBAR, if that command works, activate the Map status bar.
Is that what you were looking for?
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2024
(not an Autodesk consultant)
Murph_Map
Bottom right corner of the status bar, the icon with 3 horizontal lines on it.
Click on it and the list will pop up with all the options to turn on/off.
Murph
Supporting the troops daily.
in reply to: Murph_Map
Ya that was one of the first things I tried.  That works on the civil 3d but on the Map 3d the menu that comes up does not even have the option to pick annotative scale or visibility etc.
The commands for those buttons work ie annoscale etc but the menu options to show/add those buttons don't appear to exist.
in reply to: Alfred.NESWADBA
Ya i had tried that one as well.
That brings up a map status button but does not add the annotative buttons for scale and visisbility....well at least not in map 3d.  It works on civil 3d just fine.
Murph_Map
What version of Map3D are you using?
Murph
AutoCAD Inside the Factory
