AutoCAD Material Texture
I added an image in texture material when I open the file in another pc the texture material images disappear because the path of the texture image file is not found.
Is there any way to keep the texture images save in material permanently so if I change the path of the file then the texture images still remain with the DWG file?
onuresen50
You can create a Textures folder in the folder of dwg
But you want to embed textures into the dwg so there won't be a need to external images?
ennujozlagam
yes you can embedd images file in your dwg. see screecast and see if helps. thanks
I don't want to create an external folder,
I want to add that texture image in material for permanently so when I sent the file to another user the texture image with the material is also sent with file.
and can we embed the texture image in the material?
How can i embed texture image in materials?
ennujozlagam
maybe this one help, refer to this LINK. thanks
Alfred.NESWADBA
Use command _ETRANSMIT to create a ZIP from the dwg-file + all referenced files, so the image you used as texture will be transmitted too.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
