AutoCAD Forum
AutoCad lock Layerstates in Layout sheet files
5 REPLIES 5
emmahalenko
439 Views, 5 Replies
Hi, I am trying to lock a layerstate so that my Layout sheet files can have multiple tabs with the same plan and different layer states on them. For example, in model space I have 3 layerstates: Floor plan, Finish plan and RCP. I want 3 tabs in the layout sheet file locked to each layerstate. Right now, if I change the layerstate to RCP, all 3 tabs show up with this same state. Would be so grateful for a solution.
5 REPLIES 5
pendean
in reply to: emmahalenko
A viewport in a layout only shows layers that are on/thawed in modelspace.
A simple sentence with no hidden meaning. Now with that knowledge, do you see how what you are doing is failing?
TO do what you want, you need to follow this tip https://www.youtube.com/watch?v=j50lQOSGSw8
This is from HELP https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to...
And here is an online Tutorial https://www.cad-notes.com/using-multiple-layer-states-in-multiple-layouts/
HTH
Look through the solution(s) listed >here<
Then post back if you need more help.
(reply to the author of a post you don't understand, or need help with- you will get better results that way)
rkmcswain
in reply to: pendean
Minus any layers that are frozen only in that viewport.
Plus any viewport layer overrides you apply to those layers.
R.K. McSwain     | CADpanacea | on twitter
emmahalenko
Thank you.
Do you have an idea why layerstates are a thing if they aren't usable in Layout space? Seems like doubling your work if you have to then VP freeze all the layers you don't want visible in that Viewport.
pendean
Is this what you are doing by chance, or something else? https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Viewpo...
EDIT: and are you checking the "Apply properties as viewport overrides" toggle prior to applying the Layer State to each viewport?
AutoCAD Inside the Factory
