AutoCAD - Lock 2 lines at angle at the node
danielmRKG39
danielmRKG39
I'm running into a recurring issue I'm sure someone has solved. Looking to lock 2 lines together at a set angle between them. So the issue I have is verifying my watermain design with off the shelf parts. So I want to use an 11.5 degree angle bend or 22.5 etc and where that has to sit while maintaining clearances.
Any help would be greatly appreciated.
Many thanks,
Daniel
[ The subject line of this post has been edited to include the product name by @handjonathan ]
imadHabash
I suggest to check if Parametric Drawing and Constraints will help you.
Imad Habash
