AutoCAD - All objects disappear when i zoom extents
emma.odering
Message 1 of 11
emma.odering
I seem to have lost all my drawing on the zoom. I can see all the layers are still there & the construction lines but I can't see any of my work. I tried closing & reopening & zoom extents but that didn't work. Can anybody help please?
[ The subject line of this post has been edited for clarity by @handjonathan Original: Lost all my drawings ]
Replies (10)
Message 2 of 11
user181
Did everything disappear while you were working in the drawing or when you opened it?  If it was when you opened it try closing it and running the recover command and select the drawing.  Or try the audit command when in the drawing.
Message 3 of 11
emma.odering
It dissapeared while I was working on the drawing somehow. So should I try the audit command?
Message 4 of 11
user181
You could try audit. Did you do much work on it?  You could try the undo command to try and back up to when it happened.
Message 5 of 11
emma.odering
audit didn't work unfortunately. I save regularly but I've already closed & reopened?
Message 6 of 11
user181
If you can post the drawing here someone may be able to help better.
Message 7 of 11
emma.odering
Thankyou
Message 8 of 11
emma.odering
Drawing attached
Message 9 of 11
user181
If you zoom extents you will see a block way down below the ucs icon. If you select it and on the properties palette change the scale x to 1 from the large number it is and then zoom extents again you should see the drawing again. See attached drawing.
Message 10 of 11
emma.odering
Thanks so much!
Message 11 of 11
user181
You're welcome
