I have opened a pdf file in Autocad 2018. So far no problem. I rotated en scaled the pdf file to match the correct coordinates pointed in the pdf. I saved the result as a 2013 format dwg.
I opend my work drawing and attached the "pdf" dwg as a X-Ref file. I opend the line command and typed in the real coordinates. The first point landed in the expected coordinate. The second point (without the use of @, osnap and ortho) landed not in the wright coordinate but in the coordinate plus the old coordinate.
For example: coordinates are point 1: (4,4) and point 2: (6,6) the line should be drawn between (4,4) and (6,6) but autocad now draws the line between (4,4) and (10,10). the coordinates are not absolute but counted together.
So I have a major problem.
Is there an answer to this problem in very short notice. I have installed the AutoCAD_2018.0.2_Update_64bit today.
Sincerely,
Frans Hessels
