autocad layout scaling
Message 1 of 8
I am new to Autocad. I am always confused with autocad scale and paper size.In page setup if i select A0 paper size my 1:30 scaled drawing gets fitted.But if i select A3 paper size in page setup then my drawing doesn't gets fitted.Hoping to get some solutions to my confusion.
Replies (7)
Message 2 of 8
So nobody is here to help me.
Message 3 of 8
imadHabash
Hi and Welcome to AutoCAD Forum,
>> if i select A0 paper size my 1:30 scaled drawing gets fitted.But if i select A3 paper size in page setup then my drawing doesn't gets fitted. <<
this is normal because when you change it to A3 you have to :
  • change the scale to another proper one that fit the new sheet size (1:90) .
  • tick Fit to Paper option as seen below.
Good Luck ...
Imad Habash
Message 4 of 8
But i would like to print from layout so what scale and paper size  should i set in page setup so that my drawing gets fitted in 1:30scale of viewport
Message 5 of 8
peterm
Hopefully the below images will explain. These are all scaled at 1:50, but displayed on different paper sizes.
You can either have a specific scale such as 1:30 and then choose a suitable paper size that works, or you can choose a specific paper size such as A3 and then change the scale to suit.
Message 6 of 8
imadHabash
>> But i would like to print from layout so what scale and paper size ... <<
then you have to change the scale of your VP by Zoom ( scale ) command or by the way that you're usually follow it . printing from layouts always have the same scale from page setup plot dialog ( 1 , 0.10 .. ) but VP's scale is different and follow the print scale .
Imad Habash
Message 7 of 8
Thanks.......One more thing i would like to ask....Suppose if i set printer setting to pdf and paper size to A1 at 1:30 scale and later from pdf if i print by drawing to A3 paper will my scale be different?
Message 8 of 8
imadHabash
>> ... and later from pdf if i print by drawing to A3 paper will my scale be different? <<
( as i understand ) Yes the scale will be different if your A1 pdf printed to A3 size .
Imad Habash
