Im hoping someone could help me out. I have a msi apache with a 970m gpu, and i am having trouble with autocad 2016 and 2018. I had 2016 for awhile and it ran fine but i needed it yesterday and it kept freezing up about 2 minutes into my drawing, did it on anything i opened. I tried updating autodesk, windows, and nvidia with no luck. Also tried running with directx9 with no results, so i made the switch to the 2018 model. Now it opens but freezes as soon as its open. What is causing all of this,it is getting frustrating trying to get it to work again.
I have the same problem for a longer time. Autocad keeps crashing over the last 6 years. I tried different systems, settings, at different companies, from Autocad 2013 up to 2019. Every time i'm working on a slightly larger file the task manager says; 'not responding' for over a couple of seconds. Sometimes it totally freezes.
I think this is part of the deal.
Or is this better on mac? Now I'm on a Dell XPS i9 2.4(turbo 5.0Ghz) 16GB Ram, SSD disk - Autocad 2019. (geforce gtx1650).
Any ideas?
greetings,
F.
