AutoCAD - Inserting Blocks at list of points
Yehoshua18
Yehoshua18
Hello. On a previous drawing I used this syntax to insert a block at a list of points.
(command "-insert" "kiduach" "188537,692309,0" 1 1 0 "KM-601" )
(command "-insert" "kiduach" "188303,692336,0" 1 1 0 "KM-602" )
the last element is a text attribute of the block. However when I used this now, I'm prompted with a Entry Attribute window, and I have to manually enter in the text of the attribute. "Km-601" for example. How do i get this to work totally in command line?
Thanks for the help!
[ The subject line of this post has been edited for clarity by @handjonathan Original: Inserting Blocks at list of points ]
cadffm
Read more [F1] about
ATTREQ (current setting is well)
and ATTDIA
Sebastian
Yehoshua18
Thank you! I had a feeling it was a setting like this, spent a half an hour trying to figure it out what it was. I was searching, allow block definition to be set in command line, but couldn't find anything. Thanks so much!!
