AutoCAD Incorrectly Identifies Shortcuts as Invalid
Kyudos
Advisor Advisor
Kyudos
I have shortcuts to various control panel items on my desktop (e.g. Region settings). If I open a DWG from the Desktop I get the AutoCAD 2016 warning:
The following shortcuts in the search were invalid and ignored:
C:\Users\...\Region.lnk
etc.
It isn't invalid and I don't want to delete it, as most solutions seem to advise.
Can I turn off the warning message?
imadHabash
HI,
would you try this from your desktop area:
right click dwg icon \  open with  \  choose default program.
Imad Habash
Kyudos
It opens and shows the same warning.
elshawadfy
Hi @Kyudos!
You may try opening the file from within the application..
Beware of some viruses that move the contents f your drive to a different hidden folder in the drive, keeping only shortcuts (*.lnk files) that lead to the new location (instead of the original files) , which causes errors sometimes when you try to open the file using the application....
Does the problem happen with other applications as well - excel or word for example?
Regards..
Kyudos
That's what I tried first...same result.
The problem is that the shortcuts have no defined target... but in this case that doesn't make them invalid. AutoCAD should have a way to disable such an annoying message.
pendean
Community Legend
Community Legend
>>>..the shortcuts have no defined target...<<<
That's the probem.
>>>...that doesn't make them invalid...<<<
Not how AutoCAD was coded.
>>>...AutoCAD should have a way to disable...<<<
Nothing yet, so fix it by removing those shortcuts for now.
Kyudos
I don't want to remove the shortcuts, so I guess I'll just have to put up with the error or move the DWG.
