AutoCAD gets hatch patterns from folder that's not in Support File Search Path
I am in AutoCAD 2016.
I recently dealt with a perplexing issue regarding hatch patterns. There was a hatch pattern that would
not disappear from the list of custom hatch patterns in the Hatch Pattern Palette in the Hatch and Gradient window (below). But I had the good luck of hovering over the hatch name for a second, so it showed me the path where the .PAT file was located. It turns out that this hatch was located in a folder which is NOT included in my Support File Search Path.  (more info/questions below the picture)
The .PAT file was in the folder:
C:\Users\mmurrin\documents
When I deleted the .PAT file from this folder, the hatch pattern also disappeared from the Hatch Pattern Palette when I checked it next. I also did double check by adding NEW hatch patterns to the " C:\Users\mmurrin\documents " folder and indeed those hatch patterns were found in the Hatch Pattern Palette when I checked it next. So AutoCAD is searching that folder for some reason.
But this folder is not included in my Support File Search Path (pictured below). The closest folder is:
C:\Users\mmurrin\documents\locallisp
Why would AutoCAD search for hatch patterns in a folder outside the specified folder? Does anyone know
what exactly causes this to happen and if it should be happening?
My support file search path:
Alfred.NESWADBA
AutoCAD also searches for files in that folder, where the dwg-file is stored.
So if you are working with a DWG file that is stored in your user's documents folder the PAT-files in that folder will be found and listed.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
scot-65
Perhaps try to clear all the shortcuts found in the Recent subfolders?
C:\Users\xxxx\AppData\Roaming\Autodesk\AutoCAD ####\R##.#\enu\Recent
Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.
Aha!  That is indeed what was happening.  The file I was working in happened to be in the same folder as the indicated hatches (the "Documents" folder indicated in my original post).  I also tested this further by doing the same thing in another folder (having the DWG I'm using and a new custom hatch in the same folder) and confirmed this.  Thank you.
