AutoCAD - Geometry, within a block, not showing in a viewport. Help!
billy.bot
billy.bot
Hi, thanks for checking in.
I have some information contained in a block that I'd like to show in a viewport. The problem is the geometry will not show, as it has its own layer but is contained within a block on a different layer. So when I use the VP freeze option, the overall block layer freezes including the geometry I'm trying to show underneath.
I can get it to what I need using the layer on/off commands, but this isn't going to work in the longer term of the scheme/project.
Does anyone know a way to show a particular layers information that is contained within a block on a different layer which is frozen by the VP Freeze command please? Take a look at the drawing and example attached for the actual problem.
I've attached a block and example in this drawing.
[ The subject line of this post has been edited to include the product name by @handjonathan ]
cadffm
You have to switch the LAyer from 0 to 02.1- Anchor Plan or another Layer what are not VP frozen.
Simple and there is no other way if you want to controle the visibility per viewport.
Sebastian
billy.bot
OK, great, thank you. I'll try that.
cadffm
Oh sorry, I meaned the right, but wrote the wrong.
EDIT:
You have to switch the Layer from 0 to another Layer"X", this way  you can VPFREEZE the Layer"X"
and the '02.1- Anchor Plan' is still visible.
Sebastian
