AutoCAD - Geometry, within a block, not showing in a viewport. Help!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi, thanks for checking in.
I have some information contained in a block that I'd like to show in a viewport. The problem is the geometry will not show, as it has its own layer but is contained within a block on a different layer. So when I use the VP freeze option, the overall block layer freezes including the geometry I'm trying to show underneath.
I can get it to what I need using the layer on/off commands, but this isn't going to work in the longer term of the scheme/project.
Does anyone know a way to show a particular layers information that is contained within a block on a different layer which is frozen by the VP Freeze command please? Take a look at the drawing and example attached for the actual problem.
I've attached a block and example in this drawing.
[ The subject line of this post has been edited to include the product name by @handjonathan ]
