AutoCAD freezes
AutoCAD freezes
toonspie
Observer Observer
AutoCAD freezes
toonspie
Observer
Observer
I imported a STEP-file from a 3-way valve into AutoCAD. When I try to use the move command and try to pick a point on the valve with my cursor, AutoCAD keeps rendering for a long time and even freezes.
qnologi
qnologi
rushabhthakkar_910
@toonspie, Have a look at this..!!
(https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Graphi...)
(https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Long-d...)
Thanks and Regards,
Rushabh Thakkar.
Please use the Accept Solution button to mark any posts that provide the answer or solution.
Likes are always welcome.
LinkedIn | Instagram | Facebook.
imadHabash
You may try to turn OFF hardware acceleration from  GRAPHICSCONFIG command .
Imad Habash
paullimapa
Open dwg using RECOVER command and then run AUDIT
Paul Li
IT Specialist
@The Office
