AutoCAD - Finding dimensions in floor plan
amy.tan8CRT9
Message 1 of 8
amy.tan8CRT9
Hello! I have a floor plan given by the developers but the floor plan doesn't state the dimensions of our new home, except for a scale which I am not sure what was the ratio used. I tried doing it manually with a ruler and maths but it doesn't seem to be accurate.
Would Autocad be able to find out the dimensions?
Thank you so much!
[ The subject line of this post has been edited to include the product name and version by @handjonathan ]
Accepted solutions (3)
Replies (7)
Message 2 of 8
paullimapa
as long as there is a graphic scale then you can use AutoCAD's built-in Scale command & Reference option to set it to the accurate drawing scale.
Since the scale shows M = Meter, then this is a metric drawing.
so start a new drawing: File > New
select acadiso.dwt
enter UNITS command
change Precision to 0.000
change Insertion scale to Meters & click OK
now attach the drawing you received at 0,0
leave the xyz scale as 1 and rotation at 0 for now
now use AutoCAD's SCALE command to scale the drawing attached.
Base point is at the graphic scale's 0
Then at the [Copy/Reference] prompt enter Reference
Base point for reference again is the graphic scale's 0
2nd point is graphic scale's 1
At Specify Reference Length prompt, enter 1 which represents the 1 M on the graphic scale
Now your drawing is as if it's drawn at 1 unit = 1 Meter
Paul Li
IT Specialist
@The Office
Message 3 of 8
imadHabash
 If you have a pdf or image file for this plan:
  • Import pdf file first to your AutoCAD by PDFIMPORT (Command).
  • Import image file first to your AutoCAD. >> Click <<
  • Now.. make sure that you have a right scale size for your inserted image as described from previous message.
In this way you will have now a plan that you can get dimensions >> Click << But you have to know that you will have a not full accurate results especially when treat with images.
Good Luck.
Imad Habash
Message 4 of 8
pendean
Community Legend
Community Legend
@amy.tan8CRT9 Any reason you cannot just ask the developers for dimensions to be added? Just curious honestly. That would be the most 100% legally binding action to follow by you without the risk of getting mired in 'assumptions" in this litigious world we live in today.
HTH
Message 5 of 8
amy.tan8CRT9
Hello, thanks so much for the detailed instructions.
However, I didn't get the results i wanted. My graphic scale ended up longer but my floor plan did not change. How do I rectify this??
Message 6 of 8
paullimapa
Make sure when you’re selecting objects to scale that you select everything including the floor plan and not just the graphic scale. Then everything will scale up accordingly.
Paul Li
IT Specialist
@The Office
Message 7 of 8
amy.tan8CRT9
Thank you so much! That made perfect sense actually and it worked! Thank you!
Message 8 of 8
paullimapa
Glad to have helped. Cheers!!!
Paul Li
IT Specialist
@The Office
