@David125 wrote:It's that simple, the file crashes when I select certain blocks.
Actually, it's not that simple. You are going to have to share an example file.
You may need to clean your drawing , install the latest updates .... etc . Would you please share with us your damaged dwg file ?
Imad Habash
There are many reasons why it may crash the software. Have you tried to clean the drawing first? Does this happen in other drawings or just in a single one?
My personal blog - AutoCAD and AutoCAD Civil 3D hidden Secrets and great tips in one place -
Amplify your skills to a new level!
I recommend the following links:
Consider posting a Screencast.
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
I should clarify, the steps causing the crash were pretty simple, select item - crash. I've uploaded the offending file.
