Autocad file crashes when I select blocks
David125
Message 1 of 8
David125
It's that simple, the file crashes when I select certain blocks.
Replies (7)
Message 2 of 8
RobDraw
Actually, it's not that simple. You are going to have to share an example file.
Rob
Message 3 of 8
imadHabash
You may need to clean your drawing , install the latest updates .... etc . Would you please share with us your damaged dwg file ?
Imad Habash
Message 4 of 8
pendean
Community Legend
Community Legend
Use RECOVER command to open your file, then QSAVE: of share it over here for us to try it too.
Message 5 of 8
Zlatislav.atanasov
There are many reasons why it may crash the software. Have you tried to clean the drawing first? Does this happen in other drawings or just in a single one?
My personal blog - AutoCAD and AutoCAD Civil 3D hidden Secrets and great tips in one place -
https://skillamplifier.com/
Amplify your skills to a new level!
Message 6 of 8
Valentin_CAD
@David125 ,
I recommend the following links:
Consider posting a Screencast.
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
Message 7 of 8
David125
I should clarify, the steps causing the crash were pretty simple, select item - crash. I've uploaded the offending file.
Message 8 of 8
pendean
Community Legend
Community Legend
What's the originating source program of your DWG file? You appear to have lost all ability to use it as posted in any variant of AutoCAD, it's basically garbage when tested here.
You could try these methods yourself in case I missed something https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/AutoCA...
Good luck.
